I live in the Netherlands and I currently have an empty lot which should become the garden. So I’m fully flexible in my set up regarding watering, but looking for some advice/suggestions on how to do it correctly.
The starting point is a well in which I want to place a 3-inch submersible pump. From there, piping should go to several zones I want to eventually control using Rachio. The main question is, what should be between the pump and Rachio to make it work? Based on my research I would say I need some controller for the pump which then connects to Rachio. So pump → controller → Rachio → sprinklers. Is this correct? And what should I look for when selecting the pump and controller?
One controller that seems promising it this one from DAB. But no idea if does the job and works with Rachio.
Looking forward to some advice on my set-up to make Rachio work with my pump in the Netherlands.
