I have a basic setup with 7 zones, no sensors. It has run perfectly up until about 3-4 weeks ago, and now none of my schedules ever run. I have it set to run mornings and nights on Tuesdays and Fridays, and the calendar always shows the upcoming schedules to run, but then the time comes and goes and nothing happens. I can trigger these schedules to run manually and they will start from the app, but they will never start from a set schedule. Any help would be appreciated for troubleshooting. I have setup new test schedules and turned off and weather skips and still no good.
@artyzipp Very odd, I will have the engineering team review your controller.
Is it OK for the team to try out your zone 8 if it is disabled? If not I can have them run some other diagnostics.
Franz,
We have nothing set up in zone 8.
@artyzipp Let’s see how Thursday goes. I had the team reboot the controller as it seems the system clock was off (or had drifted too much). If that doesn’t correct it I will have our support team get you a replacement.
Thanks. The next schedule should go on Friday at 4am
