I’m having an issue where my Rachio says schedule not skipped for rain but the schedule is not running. Manual run works fine as I tested it when I turned on my system for the year but none of the scheduled runs have worked so far. I’m not sure why it would say it won’t be skipped yet it still has not run them.
I’m having exactly the same issue. I’ve checked every parameter there is and it’s all accurate. If I start the scheduled session manually it works just fine, but the scheduled sessions do not start. I turned off everything that could possibly trigger a block. There are no error messages, it just doesn’t run. Kind of useless of the schedules do not work.
I wish I had a solution. I had a V3 that they offered at a discount to upgrade and I installed that and it worked fine again. Hopefully someone messages with a fix.
