It appears my sprinklers have not been working for a few weeks now. The system works as normal, everything is blue, the schedules come on and off with notifications but my grass is starting to dye. I watched today as i manually ran each zone and nothing came on but the entire system shows blue and each zone flashes blue as if they are on and working. The app shows the zone on but nothing is working???
@mightymets06 - sounds like a wiring issue. Do you have an in-line rain sensor? Check the resistance down a zone wire and back on the common wire when both wires are disconnected from the Rachio. Also could be a cut wire, has there been any digging in the yard?
Any matter valve or pump? If the water turned on?
