The app says the zones are running. The Rachio 3 controller is lit up and looks like the zone is running but nothing is on. I tried each zone on a quick run and got the same results. Nothing turns on. How do I fix this?
There are recommendations explained at Zone fault detection
valve not opening
@MArris- by chance is there a rain sensor wired in-line on the common wire? If so and the sensor is wet/tripped, this will prevent all zones from running.
Welcome to the community.
Not sure. I unplugged it and plugged it back in. It now comes on but zones were mixed up (flower bed was now the front yard). I renamed them and switched out the settings for the zones. No idea why it did this, but at least it’s working.
