Rachio 3 not connection to WiFi
It’s stuck on blinking White light then Red.
Here’s a list of things I have done:
Number one. I have made sure my Nighthawk Netgear R 8000 was updated. Number two. I have restarted my router
Number three. I have unplugged the Rachio three and pressed the white button to drain power
Number four I have press the Wi-Fi button to see if I could connect but after holding a green and yellow light blinks but then it just does the same thing over again.
Thank you for the help.
After running the directions for a hard reset by holding down the stop button, I did receive a white/pink light but it did not progress further.
Same issue here. What I found out was the latest Android and iOS won’t work until AFTER you’ve connected. If you have an older device use that. Took me about 3 minutes once I pulled out a super old phone to do the initial setup.
Once WiFi connects, your rachio3 will download the latest update and you can use your real phone.
As an aside, don’t connect this to your main WiFi. If you have a guest one or can create a new guest network for your IoT stuff do it. It’ll save your security and private info in the long run.
