Just got the Rachio 3 12 zone! So I made sure to label all my wires from a fully functional Rainbird controller. Got it all hooked up and started through the setup. Zones 1-7 worked great, when I got to zone 8 no water on the test.
Tried another later (zone 10) no water. First thought was a local valve problem on 8, so went and manually opened both the MV and 8 and theres water flowing. Closed 8 (left the MV open) from the app did a quick water and it worked.
Ok MV problem right.
First check the app and made sure M terminal is selected; set. Tested the solenoid with a multimeter good here, and just to make sure I’m not missing anything I hooked up my old Rainbird and it worked as before! Also unplugged and started over with a clean install no luck.
So at this point I have the MV open (manually) so that I can use the system. Did a run this morning and it worked fine with the MV manually open of course.
Has to be something wrong with the unit right, maybe I’m wrong and one of you all can help!
I have a support ticket logged waiting on a response.
Thanks in advance!
Jason
