Rachio 3 – 230V/50Hz Power Adapter for UAE
Title: Rachio 3 – 230V/50Hz Power Adapter for UAE
Hello Rachio Community,
I purchased a Rachio 3 (8-zone) from Amazon USA and live in the UAE (230V/50Hz).
The original adapter requires 120V/60Hz and outputs 24V AC / 0.85A.
I purchased a 200W step-down transformer (230V to 110V), but Rachio Support could not confirm its long-term safety.
My questions:
  1. Is using the original adapter with this step-down transformer safe for continuous operation?
  2. Can anyone recommend a reliable 230V to 24V AC adapter with a compatible plug, preferably one tested long-term?
Thank you!
Transformers are very simple devices. Make sure you get the input and output voltages correct and amps needs to be at least 0.85A/20KVA( (it can be more). The plug is the only thing that’s tricky. I’d cut the plug off the one that came with unit since its no use to you and solder it onto the new one. If you don’t know how to solder, get some “solder sleeves”.
