mine used to work fine. Then the electric outlets in the garage (where the controller is located) are out. I connected the controller using the extension cord from inside the house. reset the controller (delete and reconnect) and setup wifi. Now testing zones do not start the pumps going. tried manual start. not working either.
I think you have to go back in and reenable,the master valve on the controller.
hi plainsane. thanks for responding. i saw the master valve toggle button on my app. is there a master valve inside the controller?
No, just in the app.
But Iām pretty sure this gets reset if you delete the controller then reblink
Is it working now?
