What is the interface needed to control a 220 V pump ?
What is the path of integration to include ZWave controller in the mix ?
@megatrak, great question! To control a 220 V pump, you’ll need a pump relay to sit between the Iro and the pump. For more information, please see: http://www.support.rach.io/article/216-pump-and-master-valve-support
I’d need to do some research for ZWave integration. Could you contact me on support (support@rach.io) with your current pump make & model?
Thanks! Emil
