I am going to be overseeding for the first time ever. I had a great lawn with Flex and a little over a year ago had vole issues. Then July an infestation of grubs, August another infestation plus issues with the city’s pressurized irrigation having no pressure. I presume I need to disable Flex and create a new schedule, but do not remember how. The sod company where I also got the seed said to water four times a day. I know I have read some, but want to get it right with limited time. Thank you in advance.
For me the quickest way is to set up 4 Fixed schedules, one for each time that you want it water. You can put an end date on each fixed schedule, different ones if you want to taper the watering off.
For me, faster and easier than the manual cycle/soak method.
