The local weather forecast called for rain and a rain skip was initiated. It did rain, but not at my house. The Rachio Gen 2 thinks the lawn received a 1/2 inch of water. It there a way to override the rain skip and water the next day without rescheduling?
Hey @callihd-
There is currently no way to do this. My best recommendation would be to manually run your schedule today if you don’t end up seeing any rain!
McKynzee
This is where using the area rain sensor trigger data would help. That is of course, if one was in his area…
Is there a way to manually run the “schedule” or do I have to run all zones for the same amount of time or run each separately for a set time?
Hey @callihd-
You can manually run the schedule if you would like! Directions on how to do that can be found here.
How do you override a flexible daily schedule? The directions do not cover a flexible daily schedule.
