Outdoor Enclosure Gen 2/3 Installation
I currently have a Gen 1 Rachio mounted in an outdoor enclosure and I am looking at upgrading, but can’t figure out if I need a new outdoor enclosure or not. Hoping someone can help.
My current outdoor enclosure has almost exactly 9-1/4" width, which is also the stated width of the Gen 2/3 unit. Do I need any clearance/air space around the sides of the unit? My outdoor enclosure has much more height available in it. Can the Gen 2/3 be mounted vertically instead of horizontally?
I’ve search both the knowledge base and the community and can’t find an answer anywhere.
Hey @Linn-
It sounds like you should be fine… do you have a picture perhaps? You don’t need much clearance around the Rachio 3, as faceplate is magnetic with a rocker so you can just press a corner to pull it off.
McKynzee :rachio:
This is my current Gen 1 in it’s enclosure.
Looks just like my two installs!
Any idea if a Gen 2/3 will fit in there?
I have a gen 2 unit in that same enclosure so I can confirm that it fits (although there isn’t much space on the sides).
Thanks! Glad to hear this!
That’s one good looking Gen1 installation!
As @dblagent007 mentioned, it’ll be a tight fit on the sides but you shouldn’t have a problem reusing the enclosure with Rachio 3 :+1:
