Cloud API and firmware is finished, will be live in a couple of days
Free t-shirt to whoever creates the best mashup!
This is live. Let us know if there is other information you would like.
Coming soon, webhooks!
Franz - this is great!! Almost have first app working! Just under a couple of days⦠Need a way to get the token from somewhere other than the side of the page after login - how about an Oauth exchange with a redirect uri? Or do you have something already cooked up?
@coopergleeā Awesome, I was waiting for someone to ask for that Let me figure out the best approach, should have something tomorrow.
Would like to see the variable āenabledā for each zone pleaseā¦
i.e. current -->[id:a2ad9b2b-1412-4367-bfd4-d3958977632a, name:Big Boxes, zoneNumber:6] ā add enabled:true
Thought that if a search for just the name would be sufficient, however, when the name is left blank in the Rachio App it populates with a default zone name with the number but that name is not populated from the API
@coopergleeā Good point, I added to zone. This will be promoted with the OAuth token changes.
Would also like to have the ānameā of the device come along with the device id in the /public/person/:id data. It makes it tough for a user to select a device just from the ID⦠Perhaps even the other pertinent data - status, zip, on, longitude, latitudeā¦
@coopergleeā Ok, this has been modified to return the same device data that http://rachio.readme.io/v1.0/docs/deviceid returns. Will be promoted with the OAuth token changes.
@coopergleeā These changes have been promoted to the cloud API.
@franz For the /public/person/:id service ā¦
There is a node called āruntimeā: 3643 ā¦
What does that map to? Is that the number of seconds that zone is programmed to run? Is that a total aggregate of all the schedules for that zone? Or is that something completely different?
What is the unit for that? Is that in seconds?
My runtime is 4543. Divided by 60 would be 75.71 minutes? Thatās too much since mine is 22 minutes.
What does āruntimeā map to in either the mobile app or the web app?
One more question:
/public/zone/start_multiple
Will start_multiple start the zones in series (one after another) or all at the same time?
Let us know if you have any more questions or feedback and have a great day!
Any followup questions if you could reply as a new topic and build a dedicated thread for this, thanks!
