I would like to be able to use the API to obtain the calibrated flow rate for each zone (I have a flow meter and use the app to calibrate it).
When using the app I can see the calibrated value as part of the zone information. However I can’t find a way to get that info through the API.
I can access the zone inforomation for each zone but that doesn’t seem to have an entry for the result of the calibration. I can get information about the actual flow rate after each watering event using webhooks, but I want to be able to compare that with the calibrated ‘baseline’ value for the zone.
Any thoughts on how to get this info through the API?
Many thanks
