Obtain API Keys programmatically
Hello,
I am one of the founders of http://www.getaegis.com We would like to add Rachio integration to our app.
Is there a way to login users using oauth2 to obtain api key programmatically?
Regards,
Nikko
Of course there is, just not documented or officially supported. Https://app.rach.io is working after all.
Why deal with username/password though? Having your users provide an API key or sharing access with your account and using an API from that is much more secure / straight forward.
Using oauth2 standard, an app can obtain access token using authorize endpoint to connect without handling a username and password directly.
For example:
https://oauth.rach.io/oAuth/authorize?response_type=token&client_id=CLIENT_ID&redirect_uri=CALLBACK_URL&scope=read
The client ID would be an developer application ID that must be registered before hand. I could not find anything in the docs that mention this so i assume its not supported.
can you elaborate?
@nikko If you email me at franz@rach.io I can get you all setup with OAuth2.
I see that I was mistaken about oath, seems like a good way to go. As for one of my suggestions you could create an account with Rachio for your interface, something like api@getatgis.com and have your users share full access to their controller with that account. A single API key from that account (which you can get at will) would give you access to everyone who has shared their station/data.
Franz,
I would also like to have access to a client_id so that I can use oauth for authentication in an app.
I sent you an email on 6/11/2020 but never heard back.
Please let me know if I should resend the request.
Thank you.
rudi
Sorry we only support this through company based partnerships.
Fair enough. Thanks.
