So I have an Everydrop meter wired in to the system.
Long story short I have a few extra wires over there, (all of which don’t have resistance when hooked together) but when I hook up to the flow meter the flow meter loses power.
This is echod by a volt meter so it appears to be the controller as there is continuity when the wires are hooked together.
How do you have it connected? If you can, please include the photos of the setup.
Flow meter should be connected to S1 or S2 and 24V- terminal, it should also be added to the controller via app / website. Go to controller settings and choose flow meter as an accessory. You can find more detailed info here:
