In the last couple of weeks my irrigation zones have all been going when I leave for work, which is around sunrise. I think it may be on the second run, the run/soak schedule. I’ve had the same settings for over a year and haven’t changed them, or changed where my house is, or changed when the sun comes up.
Does anyone know why this would have started happening recently?
I am seeing this issue as well. This morning it watered at 7:19am and soaked my newspaper. Sunrise is 6:50am.
One thing worth checking is the controller’s clock/time zone and the schedule’s finish-by setting. If the controller’s time drifted, or a firmware/app update changed the time zone, a schedule that used to finish before sunrise could now run later. Also look at total scheduled runtime: Flex Daily can lengthen zones as weather/ET changes, and cycle-and-soak soak periods count toward the schedule, so it may simply be overrunning rather than starting at a new time. Schedule history should show whether the start time moved or the run just got longer.
