None of the zones is working
Hello, I followed the setup direction and everything seems to work fine. The controller is connected to the WiFi and I can connect to it via the iPhone app. Nothing is working if I try to test water any of the zones. The wires are in place so what seems to be the issue.
@Tarek, can you post some pictures of your wiring? Ideally, if you had pics of both the old controller and new controller that would be most beneficial.
Can you manually turn on any of your valves by turning the bleed screw?
Thanks for the reply. It’s working now after connecting the white wire to the C Input. Two zones aren’t working and I believe it’s a fuse issue and not the controller so I need to work on it.
