I got an email informing me that my gen 1 unit was offline. I tried to reset the connection, but the unit will not blink up at all. I’ve reset the router, and I’ve cycled the power on the unit. When I do recycle the power, I get no wifi light at all…no green, no Amber, no blinking, nothing. Is the unit toast? I’ve only had it a year
@Damianjoshua Sounds like either the unit or the power supply is toast, unless there’s a chance the outlet is the issue? Have you tested the outlet to ensure it is providing power? If so, I would recommend contacting our support team at support@rachio.com with a photo of your serial number and they should be able to help more effectively!
McKynzee
@Damianjoshua - there was a recent post with a similar issue. It turned out that the outlet was a GFI outlet that had tripped. Take a lamp, with a known good bulb, and plug it in the same outlet to check it out. Any recent lighting storms?
I thought maybe that was the case, but I get a power light when I plug the unit in. Only the wifi light won’t illuminate.
Hey @Damianjoshua-
When you say wifi light, which LED are you referring to? Check out this article for more details.
McKynzee
@mckynzee - Damianjoushua has a Gen 1 Rachio device, not a Gen 2. Here are the light codes for the Gen 1:
What would I do without you guys @DLane
The first light labeled “Power” stays constant green when plugged in. The second light labeled “wifi” does not light up, doesn’t blink, doesn’t do anything. I tried to reset the wifi, but the unit will not blink up
Hey @Damianjoshua-
Sounds like something is wrong with the unit. If you would contact our support team at support@rachio.com (feel free to include this thread) and they will get you back up and running. Since it’s only been a year, you are still in warranty.
McKynzee
Well, unfortunately, it was a year April 6th. Guess I’m out that $200
@Damianjoshua - I don’t think so. a) if you check the warranty page (http://www.rachio.com/warranty) you’ll see that it is a two (2) year warranty
Subject to the terms and conditions set forth herein, RACHIO warrants that the Product will be free from material defect in materials and workmanship for a period of two (2) years from the date of purchase from RACHIO or an authorized dealer
And b) I’ve seen Rachio do right by their customers.
So like @mckynzee said, contact support, reference this string and I think they’ll take care of you.
@Damianjoshua Like @DLane said, you do have a 2 year warranty! Also, we do like to do right by our customers They will get things resolved quickly!
I totally appreciate the help from both of you. I just assumed that the warranty was only a year. Two years is really uncommon, so kudos to Rachio! Thank you so much!
Anytime @Damianjoshua! We are just that confident in the product Looking forward to getting you back to watering.
