New user - water usage calculation
I have a new rachio gen 2 device. I have set the area of my planter box as 6m2 and set up all the settings I think I have right. I have 16 drippers that use 4l of water per hour. After a couple of manual tests, the app is showing 67 litres used. This seems like a lot for about 10 minutes of testing.
Is there a calculation or another setting that I need to add for the correct usage?
Thanks
@rowdybeans - See -> Drip Emitter Calculator for Precipitation Rate & Area or https://support.rachio.com/hc/en-us/articles/115010540608-Precipitation-Rate-Calculator or https://support.rachio.com/hc/en-us/articles/115010542168-How-do-I-create-a-custom-nozzle-
Ok. Thanks. I see my issue was the conversion from litres per hour to mm/hour
How do I reset the water usage?
@rowdybeans - send a note to support@rachio.com and they can reset your water usage.
