New Install - Master Fault Error
I just replaced my Hunter box with the Rachio 3. Our system uses a pump from the lake so I set the “M” Terminal for Well or Pump Start Relay.
When I try to run the system, I get a message in the app that says, “Master valve may have wiring issue and cannot water until fixed.” I also get an email alert that Rachio detected a fault in zone master valve.
As far as I can tell, everything is wired correctly. Looking at troubleshooting steps from other posts, I tried removing the M and 1 wires and starting the system with Zone 1 and got no error. Also no error with M removed and 1 attached. But as soon as the M wire is attached, I get the error again.
[Edit: I tried the system with eveything plugged in and Zone 1 worked without error. However, when I tried to run Zone 2, the error returned and remains no matter what zone I try again.]
The only thing I can think of is that I have two wires running to the C and it was very hard to get both in to the Rachio. The Hunter was a screw-based wire system so there was no issue.
I am attaching photos of the old wiring on the Hunter vs the Rachio. If anyone can help I’d appreciate it.
@davpel - Two comments:
  1. One can move the white common wire to the other C terminal after zone 8. Both C terminals are the same.
  2. What make/model of pump start relay is in use? I think that pump start relay is pulling too much power and it may need to be swapped out with a different one.
Thanks for the suggestion regarding the other C terminal. I did move it with no luck.
I’ll have to check and find out the make/model of the relay. We just moved into this house and I have no idea where that is.
@davpel - I would not expect moving the white wire to the other terminal would have eliminated the master valve error - just making it easier to get the wires in and out with one wire per terminal.
I would look near the pump for the pump start relay as that way the AC lines running to the pump are short. Having a long 24 VAC line to trigger the pump start relay is not a problem. If you have a mult-meter, I’d check the resistivity down pump start relay line and back on the common wire.
I’ve recommended the Orbit pump start relay available from Lowe’s or Home Depot → https://www.homedepot.com/p/Orbit-1-2-HP-Pump-Start-Relay-57009/100181554 and that seems to work for folks. Looks like it is an order and wait at both of my stores, so maybe Amazon for quicker delivery?
Thanks. I’ll talk to my sprinkler guy about doing this.
Hello Davpel-
I just purchased the Rachio 3 and had the same issue. I was able to find my own solution using these simple low budget solid system. I have explained all in this below post. No need to get external help, it is really very simple wiring if you are slightly handy.
Take a look and let me know if you have any issues, I would be happy to help with wiring of your master valve.
