I have Toro vision 2 series controller. Can you provide the wire mapping for Rachio 3.
@Himurachio - Com to Com, 1 to 1, 2 to 2, … 9 to 9 and 10 to 10. Pump to M.
Looks like there may be a rain sensor that is wired into the common wire - two red wires,brown wire running off picture below with a wire joint wrapped with electrical tape. The above wiring map is for the actual common wire, not the common wire running through the rain sensor. If you want the rain sensor to be active, I’d need to see how it is wired and the make/model to update the directions for it.
I want to connect the rain sensor. Rain sensor model Irritrol RS100. Attached wiring pic. Looks like it’s attached to power and COM port.
@Himurachio - Here are the directions for the rain sensor →
https://rachio.kustomer.help/en_us/rachio-compatibility-with-irritrol-wireless-rain-sensor-ry_CwL1tP
TLDR: thin white and one red VAC -, other red VAC +, brown S1 and enable sensor 1 as a rain sensor in the app. The thick white wire that is joined to the brown wire from the rain sensor is the one that will go to the C port.
Thanks, how about remaining wires. How do they connect?
@Himurachio - in my first post I listed the other connections:
Com to C, 1 to 1, 2 to 2, … 9 to 9 and 10 to 10. Pump to M.
Thanks. I am good.
