My PWS from WU doesn't show up on Rachio?
How come my Weatherflow PWS on WU doesn’t show up as a PWS on Rachio. My station ID is KNJHILLS64.
It takes about a week for a new WU station, like yours, to go through their internal QC process and show up as an option to Rachio. This is true in case you own Gen 3 controller, or a Gen 2 controller from Costco, as those use WU network as their data source. In case you use an older controller, such as Gen 1 or 2, let me know as your data needs to be part or pwsweather network to be available to your controller (I can help with that).
Cheers,
Gene
Thanks, I have a gen 3. Appreciate the info!!
I am having problems location my station as well. https://smartweather.weatherflow.com/station/9783
Station: KMINEWHA14
It takes about 5 days before WU will clear your station to be visible. The go through there own QA to check everything out before letting it be used.
What @Santo4413 said is true, unless you have a Gen 1 or 2 controller. If this is the case, let us know and we can help you out accordingly. :cheers:
@nhfd3, I could see your weather.
Can you add my wu to rachio. https://www.wunderground.com/dashboard/pws/KTXAMARI350/
