I’m on Flex Daily, Spring/Summer 2020.
I discovered the Calendar, and found that the watering times are ridiculously short in some zones.
I’m attaching a pic from 6.10.20, when the temp was actually 101, not 97. Why would my lawns water for for an hour and 14 minutes, while the front gardens water for only 3 minutes, and the front trees and shrubs water for only 5 minutes? This makes no sense at all. -
Also, my beautiful azaleas are dying. That zone (7) worked perfectly on initial setup, and in manual watering. But as you can see from the calendar, it is not included at all in the program. It never has - on any day - since the seasonal change took place. What’s happening?
