@voigtritter, are you planting flowers? If so, I’d recommend using the vegetation type Annuals for your pots. Nozzle type is probably an emitter? Here’s a support article with some photos of nozzles out in the wild.
The hardest aspect to setting up watering times for pots is the size of pots varies greatly; even for one user. If that’s your scenario, it might be best to customize the nozzle for each pot to try to match them to the pot size and water requirements of the plant. Here’s a good 3rd party article that goes into the details of drip system design for pots. ![]()
