Master valve using motor operated valve
Getting valve master valve fault about 50% of the time. the valve connects directly to the Rachio controller. Would it be best to use a relay to drive the motor operated valve? This way the controller always sees a amperage pull like it does with the solenoids. Please help me, Thanks
@trextkd- a relay that would connect the valve to a separate power supply is what I would recommend.
Welcome to the community.
