Just checking in on what is the status on adding the functionality to be able to use the master valve on a zone by zone basis versus the current all zones or none option.
This would be a great help to many I am sure
Thanks in advance
Thanks in advance
A set of relays would solve that. Need a relay for every zone that turns on Master Valve. Unfortunately, its a little harder to find 24VAC relays than DC. Cheapest I found on Amazon
The relay idea is not what I’m looking for. It seems like this is a logic idea that can just be programmed into a Rachio software update by the manufacturer.
