Master Valve and Ball Valve Plumbing Help
Today I noticed a small leak [1] in my pipe and I was wondering if it makes since to have a master valve and the ball valve since I am going to have to fix the leak. I’m hoping I can just put some glue around it, but I might have to replace everything. Open to suggestion and recommendations on best setup.
[1]
Other setup pics
I’m also thinking I might need to install a backup preventer but since I am on a hill I am sure it will make everything damp around my foundation. Open to other suggestions on my setup.
@chadholdorf - having the ball valve will let one work on the master valve without turning the water off to a larger part of the water system. Even if you need to cut out the pipe to fix the leak I think you could limit the cutting to elbow in question. One would need to add a coupler and a small piece of pipe on the vertical run to get the new elbow down to the manifold level.
If you want to replumb more of the setup so there won’t be a coupler right next to an elbow, then I’d plan ahead and have enough vertical run (at least 14", I’d add another couple for comfort) to put a flow meter in at sometime in the future (would require a Gen 3 controller too - if you don’t have that).
Thx @DLane. The elbow is where the leak is. I just don’t think I used enough glue and now it has a small leak. So I think I have to cut above the elbow, add a coupler like you suggested and then put in a new elbow. I think that is what you are suggestion. Thx
I do have a gen 3. Was debating if it is worth the $$ to buy a flow meter.
In addition to the sound advice from @DLane , I would also make sure to use primer on the mainline. Primer will give you a stronger adhesion of the blue glue to the pipe.
It is a standard practice to use primer and glue on any mainlines since they are normally subject to constant pressure.
Thx @spscoutenPhD. Guessing that would help. That makes since about the pressure. I noticed even the ball stop valve has a small leak on the shutoff switch. Should I be using something else because of the main pressure? Thx again.
I typically recommend the brass ball valves since they are more stable under most of the nominal irrigation pressures. The PVC valves are not meant for frequent use nor under higher pressure situations.
Teamwork, makes the dream work.
@chadholdorf,
Like I mentioned in your other post, you also don’t have any backflow prevention in this system, so it might be something you want to look at. If you end up installing the backflow device you will be re-piping that section anyway and it will include a shut off valve (two actually). Based on your setup, I personally don’t think you need a master valve…
Hi! Thanks for the tips!
It sounds like you’re at the point where a small leak could turn into a bigger rework, so it’s good you’re thinking ahead about valve placement instead of just patching it. From experience, simply putting glue or sealant over a leaking joint is usually a short-term fix at best, especially if it’s a pressurized line. If the joint is already compromised, replacing that section is the safer move.
Having both a master valve and a ball valve does make sense. The master valve gives you full system control, while a nearby ball valve lets you isolate a smaller section for maintenance without shutting everything down. That’s especially helpful if you ever need to repair or upgrade parts later.
In a similar situation I dealt with, I initially tried a quick patch, but it started leaking again within weeks. I ended up cutting out the damaged elbow and installing a new section with a ball valve nearby, it made future maintenance much easier. I also found a helpful guide from Plumber Singapore while researching proper tap and valve setups, which reinforced the idea of doing it right the first time rather than relying on temporary fixes.
If you’re already opening up the pipe, I’d suggest planning your layout cleanly, avoid placing couplers too close to elbows, and leave enough straight pipe for any future additions. It’ll save you headaches down the line.
