New Gen 2 user, have a Flex setup. I want to do a cup audit of my zones because the last time I did it several years back it was lower in every zone than the suggested values for the head type in Rachio’s app. For now I’m using the default but sadly I think my irrigation contractor probably spaced the heads out too far when the system was installed 10 years ago perhaps to save $$$ or something so in many rotor zones I’ve previously measured anything from 0.4-0.6 per hour (compared to 1 in default) but I want to “check again” in the hopes perhaps I wasn’t careful enough with my measurements…
So… if I want to do a 20 minute zone by zone test will the quantity of water I lay down manually affect my Flex schedule, or does Flex “ignore” manual waterings (like my old Rainbird ESP did)? I ask because doing 20 minutes a zone is quite a bit of water and I’d like to do the test the day before a scheduled Flex watering in the hopes I don’t “waste” a watering and the Rachio will automatically dial down the next days watering since I watered so much the day before…
Hope this makes sense…
