A function should be added to run existing watering schedule anytime manually. Every existing controllers have that function. Very ackward to set time and date everytime You want to run manually! Using quick start defaults to 3 minutes so you have to program each zone!!!
@Peaserl If I understand what want, you can already do this. On the home page of the app select the Quick Run button in the lower right corner. You can then start a Quick (ie manual) run by zone or schedule. If you select zone then you can specify the number of minutes it should run. If you select schedule then the schedule starts up.
Thank you
Thank for the answer I had no idea you could do this.
Perhaps bring this advice to a more obvious place on the web site,
