What should the Water Duration be for a 20 minute cycle twice per day with a 12 hour soak in between? I had the duration set to 40 minutes, but the schedule is only running in the morning.
I think I know what is going on. That zone is a drip which we don’t support cycle/soak (we should for manual ) Can you try changing the nozzle type to rotor head and then make sure you have these settings on “Advanced” (it is what they are set to now). Changing the nozzle type should allow cycle/soak to work as normal.
