Looking for a pro in Rhode Island area
Technically and mechanically my system is running fine. Sprinklers installed 6 years ago ive maintained it since then upgraded to rachio and set everything up on my own. Since then we have had water restrictions to some days and other things introduced. Looking for someone that can review the schedule / settings, run times, and check general coverage see if things are running in the most optimal way. Not over or underwatering and see if it would make sense to swap out a few of the existing heads for some higher efficiency ones.
Hi Dmitriy,
Sure, I can help with that.
I have extensive experience with irrigation systems and water efficiency. If you’re open to remote support, I can guide you through optimizing your system’s performance and offer advice on water-efficient practices.
You can reach out to me on my email here
Colin
