Hey everyone - have a quick question I hope someone might advise me on -
I have a well-set up fairly simple 4-zone Rachio 3 set up. In a continuing effort to save water, I decided to try the K-Rain nozzles on one zone (and then expanded to a second). All the sprinkler bodies are 4" RainBird PRS-SAM (I have pretty high water pressure) and was using RainBird nozzles.
I had calibrated the Advance Settings in each zone by measuring square footage, turning on the water for 5 minutes and noting the gal/m, and then plugging into the 96.25 formula to get in/hr (which I entered for each zone in Advanced Settings).
In the 2 zones I mentioned, I replaced ALL the nozzles with the K-Rain (green) 13’-15’ rotary nozzles, and I think it’s going to work out great for me. Just a smile of overlap, far less windblown mist, adjusted so the walkways don’t even get wet!
Here’s the question: when I updated the nozzle designation in Advanced Settings for the 2 zones, Rachio automatically recalculated (downward) the nozzle in/hr. HOWEVER the K-Rain packaging clearly states that these nozzles have a precipitation rate of 0.44-0.48 in/hr.
Do I use the rate that Rachio calculated based on my earlier reading of the water meter and use of the algorithm? Or (since I’m using the same head everywhere in a zone) I just plug in 0.44 in/hr and leave it at that?
Or does it really not make all that much difference?
Thanks in advance and appreciate any guidance on this!
