Is there any way to adjust the run time when running a zone manually from the buttons on the controller? What’s the point of 3 minutes?
I generally make manual runs from the App where you can indeed adjust the run time. One reason for short runs (I typically use 2 minutes), is to find the heads to mark them prior to aerating the lawn.
From the controller, I didn’t know manual operation was possible. From the app, I wish I could set my default run time to 15-20 minutes to allow water to reach drippers and for me to check each one. Manual operation is not a quick process.
