I’ve installed my Gen 2 unit years ago, and a couple of times I needed to reset or change the Wi-Fi it uses. For this process, the unit transmits a (temp?) SSID for the app to connect with (a name like “Rachio-43xxxx”). Once the unit is connected to our own wi-fi channel, this Rachio channel is no longer needed.
QUESTION 1:
Do I have the above correct? Am I understanding the process?
QUESTION 2:
So since the setup’s done now, and the Rachio-43xxxx setup channel is no longer needed… is it supposed to still be there, broadcasting 24/7, forever and ever?
I can still see it on my analyzer scans, and am a little concerned that anyone in the neighborhood knows that the device is present, (awaiting connections?) and possibly ripe for some exploit that the Rachio folks have yet to discover.
I just wondered if this is nominal, a firmware bug, or the unit thinks that something was never completed. TIA for any feedback.
Al
Wow, this support option is great!
I have them same thing showing up and when I first noticed it I also noticed the Google Home thinks it’s offline even though it isn’t.
I have leaned of two options, one of which worked for me:
Power cycle the unit: Disconnect the power source for a minute and then connect it again. When the unit re-boots, it’ll realize it has a working real wi-fi then - and finally turn off it’s own setup channel because it’s not needed anymore.
In some devices, Windows 10 and 11, the wifi signal may actually be gone but your settings have cached (“remembered”) the ssid and keep showing it as a possible connection to try. You need to manually forget the network on your computer:
- Access Network Settings: In Windows 11 settings, navigate to “Network & Internet” > “Wi-Fi” > “Manage known networks”.
- Forget the Network: Select the SSID from the list and click “Forget”.
Thanks to Henry @ support for some ideas.
I agree, I think the bigger issue might be the cached networks. For whatever reason Windows really likes to remember wifi networks, and it is confusing as they look like they are “available” when you look at a network scan.
But to answer your original question, I’ve never had the factory SSID continue to broadcast after initial hookup to wifi…
