I just bought the version 2 this spring. Love it!!! I want to know what’s changed from V2 to V3? I do not use the flow control valve or anything else. what are the advantages to upgrading? are they worth spending the money?
@dbow32 - here are the changes that I’m aware of:
- Weather Intelligence +
- 5 GHz WiFi band
- Improved wiring terminal
- On unit run, pause and skip buttons.
See ->
Wireless flow meter
I love the leak detection and low flow features.They only accompany the valve shut off when a major leak is detected when you push the button to allow that part of the feature.
The low flow alerts allow me to see if a valve fails to open or if nozzles are getting clogged due to hard water.
