Hooked up my new rain sensor and I am having problems with it constantly activating and deactivating. Sensor light stays solid, so it never looses communication. Yesterday it happend 243x. From my understanding, many other people have had this happen, but from the post I have read did not see any resolution.
Due to this communication loss, it waters my lawn in 3-4 second incriments…
From the videos I have seen I think it is wired correctly. White to common, Brown to S1, and Reds to 24v.
Move sensor’s white wire to 24v- terminal. You’ll have two wires there, but that should not be an issue.
Issue is that rachio’s Common terminals are actually tied to 24V+ terminal and zone wires are pulled “down” to 24V- when active.
P.S. This is the first time I’ve noticed the new screw type terminals.
I very much like the change @Rachio.
As @Gene said. It is of help, here is an official page, Rachio compatibility with Irritrol Wireless Rain Sensor. Guessing the screw terminals are from the R3 8-zone from Costco. I do like the push connectors, but the screws might have a slightly less change of loosening?
Screws are a great improvement considering you only really need to use the screwdriver during the install. Here are just some of the advantages I can think of from the top of my head:
Support multiple wires per terminal
Support wider range of wire sizes
Supports stranded wires
Close to unlimited reusability
Easier to clear in case the end of the wire breaks off
Less likely to be broken due to excess force
Easier to test with a multimeter
Most connector issues can likely be repaired with a quick trip to a home improvement store.
Etc…
