Interesting initial schedule setup
Just got my unit in yesterday and everything is connected and setup. I chose “Flex Monthly” as it was what showed up as “recommended.” I pretty much set everything up as “Recommended” because I want to give the ML a chance to kick butt. The resulting schedule is quite interesting with very sporadic total watering. It is supposed to rain next week, so the long duration between the next watering makes sense.
My question is that does this schedule seem normal? This watering period seems VERY long and infrequent (maybe that’s the ML in action?). What do I do if my grass seems to do poorly with this schedule? Also, it it somewhat weird that the Street Side Grass (smaller chunk and stationary heads vs rotary heads) is such a short duration? Everything is set on soak cycle (as suggested).
Also, we bought the house in February and the “South Side Lawn” seems like it has been underwater in the past. The house is newer (under two years) and the sod still shows the “lines” in it. The default in the settings shows 9" roots but I doubt they are that well established. Should I mess with some of those settings for that zone?
Flex Monthly will have “set” watering frequency each month, that increases with frequency as average temperatures get warmer. It doesn’t react that well to dynamic temperatures as every month has a set watering frequency (i.e. every 5 days).
The system will try to do deeper, less frequent waterings, hence the longer watering with less frequency. This article explains some other concepts of the schedule.
https://support.rachio.com/hc/en-us/articles/115010378767-Flexible-Monthly-Schedule-FAQ
The article above explains how to adjust Flex Monthly frequency. If you do increase frequency I would just lower minutes a bit. Also, you might want to try one or more zones in a Flex Daily schedule to see how that performs. You can also reach back out to the community as we have a few power users that like helping people get their systems tuned up. This article explains the Flex Daily concepts.
https://support.rachio.com/hc/en-us/articles/115010541708-Flexible-Daily-Schedules-FAQ
Are you sure that value wasn’t changed? The engineering team simulated that zone in the same schedule and got 33 minutes? I would try recreating the schedule.
Up to you, shorter roots will increase frequency and decrease watering time.
Welcome to the community and have a great weekend!
Is there any way to know what that frequency is supposed to be? Seems crazy interesting it’s only recommending 4 waterings with the flex monthly!
I recreated it and it went back to 33. Super weird - must have fat fingered something?
This sounds like a fun way to make friends, ha. If someone chimes in I’ll be happy to work through it.
I’ve gone ahead and set up two zones as flex daily and two as flex monthly. I’ll keep an eye on watering and go from there.
I feel like “Supposed” to be is relative :slight_smile: I did notice that your grass type that was chosen was warm season grass and just noticed that you are in Montana. If your grass goes largely dormant for the winter (which I assume it does) you should have cool season grass which will very much change the frequency. Try that and you will see a large change in frequency.
Your disabled zones are marked cool season grass, so it does look like your active zones were changed to warm season grass?
I KNEW I was doing something wrong. Way shorter schedules and way more frequent now.
So now will the system skip if it’s supposed to rain or has rained?
Yes, the weather intelligence will predict those events. You can adjust the thresholds in the weather intelligence settings.
