Hello. I have a Hunter XCore with a rain sensor. See wiring image. Could someone guide me on the wiring please? I want to install a Rachio 3, which wire goes where?
I would suggest the following steps:
- Label all wires
- Run through each zone to make sure they all are working as is
- Wires
- Move 1-7 from Hunter to Rachio 1-7
- Repeat for C
- Move Hunter P to Rachio M
- For now, I would not connect the sensor. With Rachio’s weather, most seem to not use the rain sensor
- Do not connect Hunter’s 24 VAC to Rachio, rather, use the Rachio supplied power supply
- Rachio app
- Add controller
- Configure the Pump or Master Valve in the Rachio app
- Test the zones
- Configure the zones, some find this a bit overwhelming at first but we are here to try to help
Sorry, I went past the wiring
