Since the recent update and addition of Usage, my usage data is nowhere close to being accurate. It was working fine before the update but now it is crazy high.
I am only running a single zone right now which waters only my shrubs yet it is showing approximately 10,000 gallons usage for just 4 minutes of running. Considering it is fed by a 1" PVC pipe, this is basically impossible.
I have the same problem. I was shocked to see my usage data and thought we might have a major leak. Hence, I tested zone by zone in a couple of zones with and without Toro Flow meter. The numbers are obviously large with the Toro Flow meter. I have the TFS-075. For example, I have two popup to water 2 circles of grass in one zone. One is radius of 7 ft and another is a radius of 4 ft. It says it has taken 30 gallons to water for one minute.
Hence, something appears to be broken with Toro integration with the new release. I hope Rachio fixes it soon. I really wish I could see zone by zone data especially when I dont have two zones running in parallel.
We believe this is a firmware issue. @Devin is working on a fix and we will send out to your controllers as soon as we are finished. Thank you for reporting this!
Wow. I am amazed and very happy with the immediate response and the quick handling of the issue. Kudos to Franz and the Rachio team. I tested the same grass circle for 1 minute again just now with TF-075 flow meter and Rachio says it watered 3 gallons which seems right.
Again, thanks for the excellent service from the Rachio team.
