I’ve recently relocated to a new residence and brought along my Rachio Gen 2. However, the new property is equipped with a Hunter Pro-C featuring a Toro rain sensor, and the wiring setup is notably more complex than what I had at my previous home. As a result, I find myself in need of assistance. I’ve grasped the wiring configuration on the right side: the White COM wire ought to be connected to the C terminal in the Rachio, and each Zone wire should correspondingly connect to its designated slot in the Rachio. However, I’m puzzled about the wiring on the left side.
- Could you shed some light on the purpose of the bright red, blue, and white wires and where they should be routed?
- Additionally, concerning the rain sensor wires (I’ve identified five: two red, one beige, and one brown), could you please advise on their proper placement in the Rachio Gen 2?
- Lastly, I believe I understand, but I’d like confirmation: is it correct that the Yellow and green wires do not require connection as they serve as power for the Hunter Pro-C?
Thank you for your assistance.
