How is watering schedule zone SEQUENCE determined?
Re: Rachio 3 Question
My zones are set up and working perfectly. In setting up a watering schedule, how is the SEQUENCE of the watering determined? Can I specify the SEQUENCE of which zones I want watered in a specific order? Or, is the SEQUENCE always pre-determined by the sequence of the zone numbers? Thank you, Dale
Yes, you can specify the zone sequence: if you open up a schedule in the app, select the watering duration option and you’ll be able to drag zones up and down to create the sequence that you want. The controller will water zones going from top to bottom (and potentially back around to the top if you leverage the Cycle and Soak functionality like I do).
If I recall correctly, there used to be the 3 vertical lines in this section to give a visual indication that these watering durations could be re-ordered, but that doesn’t seem to be there anymore.
