Hey franz is there a way to have the history in order instead of this
You probably have the reduce water hammer option turned on which means it will start the next zone before shutting off the current zone. So it is in chronological order
Yea you’re absolutely right. I have the water hammer enable so the only way you get history in order is if you disable the water hammer ??
Well it technically is in order. It starts the next zone before ending the current zone it is running. So the start of the next zone will occur before the completion of the previous zone. Disabling the option would result in the first zone completing before the next one.
Ok cool I’ll just leave it alone than I just wanted to make sure everything was working properly in the history zone ordering. Thank you jpedrego for your quick reply
