I know this request has been made several times in the forum, has there been any progress on this feature? It would be a great feature to know how much I am spending per zone on Water to help prioritize new landscape ideas or watering techniques. I would presume Rachio has all this data and adding an API to get this data would be pretty straight forward.
This feature has not yet been added, however we are looking to improve our usage reporting moving into this watering season. Out of curiosity, do you have a flow sensor installed, or do you just use Rachioās usage estimate?
Thanks for the response. I donāt yet have a flow meter inline, but Iāve looked at adding. I have however measured the GPM for each zone so even a report of number of minutes per zone, would be great.
Water usage stats, by zone, with no flow sensor insertion effort needed, and no wires needed to serve as an antenna for otherwise damaging surge spikes into the Rachio.
Rachio would have a ācalibrationā screen, showing all 8 or 16 zones, with a spot to fill in GPM, as measured manually at the water meter for each zone.
@a0128958@jsjames I like the idea of hard entering your meter readings, it feels like a good compromise when trying to get accurate usage without the expense of flow sensor installation.
Itās a reasonably accurate solution, that avoids major effort and expense. No purchase of 8 or 16 flow sensors (and the ones made to be outside are expensive). No installation of 2 or 3 conductor made-for-underground cable to each flow sensor (a lot of work; serves as antenna to bring in bad surges to Rachio).
And with you guys being a s/w company, this should be a lot easier than a h/w solution.
This is simply incorporating āin Rachioā what I outlined a few days ago āoutside of Rachio.ā My outside of Rachio solution is about $600 - my guess you guys can do it āin Rachioā for much less.
For what itās worth, there are some of us (like me!) who purchased and installed a flow meter in the hopes that one day in the not so distant future Rachio will be able to provide us with the actual volume per zone. Wtih a baseline volume established (per zone) we can monitor (manually or through badge alerts) for events that yield >150% of our expected baseline volume, thus indicating a leak. Add to that the power and benefit of this new data - with actual volume per zone users will be empowered with the information they need to make decisions about the cost-benefit of maintaining specific plants (i.e. veggies vs. turf).
Iāve also been looking for a way to download the watering history detail that is visible in the History panel. Would be great if Rachio would provide this capability.
Even with the new update, I still donāt see this feature enabled. It would be extremely helpful to have this capability and canāt be all the complicated to implement. Can we get this capability?
Just adding another voice to the request for a download history by zone feature. Need help writing the feature? ā'As a user, I can download a CSV history file with entries by zone so I can more accurately estimate my irrigation water usage and savings.ā
The total hours history at the controller level by itself is not useful from a financial saving perspective⦠since we donāt pay for water by the hour.
