Nah, I’m using these cups:
https://smile.amazon.com/dp/B005C5OP8G
I calculated mL in the spreadsheet specifically so I could put it into the watering schedule website.
I read a bit more on what values to use for nozzle inches. Like you said, it sounds like I want to use the average of my cups (0.46 in/hr), and then dropping the efficiency to 43% should add more watering time to help the under-watered spots? I guess I just have to make sure I’m not flooding the higher-values spots. I’ll have to adjust the throw of some of the nozzles.
I’m still super confused why the website is giving me 0.05 in/hr. Since it seems to be an Orbit site, is it just assuming I’m using the Orbit cups? I had to double-check and it never asked me the area of my cups, so that makes sense.
If so, your math seems to be correct that that’s probably the disconnect I wasn’t seeing. That makes a lot more sense! Thanks!
