Help move from Hunter X-Core to Rachio 2nd Gen
Hello,
I would love some help with the installation of the Rachio 2nd Gen. I just moved into a new home and the sprinkler system was set up by the construction company, it was hooked up to the Hunter X-Core and it looked like this:
I did the installation of the Rachio but the zones wont turn on. This is how I set it up:
My Zones are not running. I think I might have the wiring of the SEN(s) and/or the C and P wrong. Please Help!
Thanks!!
I think “C” needs to be put in the “C” slot on one of the two zone bars. It is the “common” wire connected to all the valves.
@jlobo26 did @sbillard’s response help you out?
What are the sensors listed there? SC and SP? What do they mean?
Contractors keep telling me their customer wants to hook up a Toro Precision Soil Sensor to your controller. Is it wired into the SC and SP ports? Will your controller work with a Toro PSSKIT?
I am having the same issue. My wiring must be off but i can’t seem to find where I went wrong. I agree with @sbillard though about your C wire. Here was my Hunter setup
Last post fixed here ->
