Heat wave and Crop Evap
The problem is adjusting for unusual heat wave that takes a good setup under normal conditions to problem when heat comes and you are on vacation or away.
I read the noted discussion and replied there.
Basically suggested calculating the difference between irrigation and evaporation and adding frequency to make up difference, thus Balance is actually “0”.
