I have left my flex schedules on this winter to see how it works. The last several days the temps have been dropping into the high 20s at night. Last night my front lawns ran and iced everything up pretty bad. The night before my front planters ran and it froze that night as well.
We have been getting frost warnings for our area from the NWS so I am not sure why the Rachio is still deciding to water.
@cwagz, do you know if you’re using a PWS or NWS as your preferred weather station? The Iro should skip watering anytime the temperature is at or below freezing. I’m curious if your preferred weather station might be reporting inaccurate data.
@cwagz, awesome! Glad to hear the IFTTT recipe setup went smoothly for you!
This is the only recipe I’d recommend keeping an eye on as Flex schedules will automatically account for rain when calculating the soil moisture balance on a daily basis. The rain delay will override the Flex Schedule(s); however the Flex Schedule(s) should skip automatically unless the forecasted rainfall is under the required refill amount to meet your Allowed Depletion settings. Just curious, did you need to use this to comply with local watering restrictions.
@emil
Regarding the 1 day delay for rain. KF70 might report rain a little funny. It has been raining on and off for the last several weeks and it does not seem like KF70 reports it correctly unless it rains a lot. The rain only shows in the 1 hour column. I am not sure if this effects the way your software tracks it but often the rain seems to go unrecorded by the flex schedules. I figured the 1 day delay would help with this. I notice other NWS stations log rain in the 6 hour column as well. Is KF70 not tracking accumulated rain? The other stations nearby are all coastal so they really won’t work for my location.
It is against the rules here in CA for me to water if there has been any rainfall. I think I get a pass for having a weather based controller but I don’t want to get turned in.
My controller wasn’t scheduled to water this morning but the Schedule update shows that the schedule was skipped due to freezing. Should the schedule log say that the schedule was skipped if no watering was planned?
