I have a Flex daily schedule set up to finish by sunrise. It contains 5 zones.
When I set it all up the calendar said the first run would be 6-7 hours. However, when it was time to start the run at 11:00 pm it decided to only do one zone. It waited until 4:30 am and ran the one zone. The calendar said the other 4 zones would be done the next night.
I thought the problem might be that the zones showed moisture levels of 1%-5%, probably because I did quick runs of a minute or two when testing the wiring. I emptied the remaining 4 zones.
The second night, when it was time to run it decided to only run 2 of the 4 zones. The other 2 zones were postponed until the next day.
The third night it only did one of the remaining 2 zones. The fourth night id finally did the last zone.
What is causing this? The various zones are generally expecting to run 30-120 minutes, so they can easily fit in a single night. Is this typical? I am in Phoenix; when we get to hot weather it will be disastrous if the schedule postpones zones for 2-4 days after they get to 0%.
